- Mail forwarding fails, error in
/var/log/maillogplesk postfix/smtp[8055]: AABBCCDD11: to=<[email protected]>, relay=<relay_host_hostname>[203.0.113.2]:587, delay=0.16, delays=0.02/0.02/0.08/0.03, dsn=5.0.0, status=bounced (host <relay_host_hostname>[203.0.113.2] said: 550-Verification failed for <SRS0[email protected]> 550-Previous (cached) callout verification failure 550 Invalid sender <[email protected]> (in reply to MAIL FROM command)
Sender Rewriting Scheme (SRS) support is enabled in Plesk, however it is not supported on the relay host.
Recommended solution is to enable acceptance of SRS for emails from Plesk on the relay host.
Disabling SRS support in Plesk (not recommended).
Warning: This solution will make the environment less secure because the sender's email policy will be ignored.
In case it is not possible to enable SRS on the relay host, SRS can be disabled in Plesk following the next steps:
Connect to the server via SSH
- Open the
file and find the following line:
/etc/postfix/master.cf
plesk_virtual unix - n n - - pipe flags=DORhu user=popuser:popuser argv=/usr/lib64/plesk-9.0/postfix-local -f ${sender} -d ${recipient} -p /var/qmail/mailnames
- Add
to the end of the line:
-s
plesk_virtual unix - n n - - pipe flags=DORhu user=popuser:popuser argv=/usr/lib64/plesk-9.0/postfix-local -f ${sender} -d ${recipient} -p /var/qmail/mailnames -s
- Restart the
service:
postfix# systemctl restart postfix
