Keeping Tabs with Plesk Obsidian’s Advanced Monitoring Extension [VIDEO]
Plesk is continually evolving. We released Plesk Obsidian just a few months ago, and it’s by far our most powerful management platform yet. Jam-packed with new features, Plesk Obsidian also introduces six new extensions that make the Plesk experience better than ever. Each extension offers users enhanced usability, tougher security, and maximum productivity. One of these new extensions is the Advanced Monitoring extension.
Advanced Monitoring replaces the Server Health Monitor component as the main feed for monitoring the health of your server. The Advanced Monitoring extension works in tandem with Grafana – an extension that displays server metrics as visuals, graphs and dashboards. The result is a powerful combination that optimizes both the flexibility and control of your Plesk account.
This article will fill you in on everything you need to know about the new Advanced Monitoring extension. We’ll first look at why the extension is so important and the problems it solves. Then, its main features, and finally how you can start using it.
What problems does Advanced Monitoring solve?
Keeping track of your servers can be a tricky and time-consuming task. But anyone who’s suffered an unexpected cut knows it can ultimately save you a whole lot of time and hassle. That’s why, a tool that can automate the monitoring of your servers is an invaluable asset. However, it’s important that it actually makes the process easier and upholds server monitoring best practices.
First on the best practice list is that the tool can watch various system metrics around the clock. Alerting you whenever there’s a problem. The Advanced Monitoring extension does this by tracking your server resources usage day and night.
It then notifies you when the usage of one or more resources reaches a pre-defined threshold. Because it’s essential to be instantly alerted of critical issues in order to handle them right away. Advanced Monitoring sends you emails according to your preferences and limits so you never have to worry about breaks again.
Another best practice is being able to monitor current and historical data of your server usage. This can help you get a feel for the overall state of your Plesk. Ensuring you don’t overload your server, and allowing you to plan accordingly for future needs.
Of course, all this data is useless unless it’s offered in a clear, easily-digestible manner. Grafana is the leading open source software for time series analytics. The extension displays data in Advanced Monitoring through graphs and dashboards that are highly customizable and visually appealing.
Main features of Advanced Monitoring
Let’s take an overview of Advanced Monitoring’s full feature list. With the Advanced Monitoring extension, you can:
  • See detailed reports on your server health
  • See how server health parameters change with time
  • Change the displayed time period
  • Keep track of the system resources’ usage on your server
  • Configure email notifications to inform when one or more resources’ usage reaches a pre-defined threshold (this feature is on its way).
One of the best things about the extension is that it’s ready to go out-of-the-box. Both the Advanced Monitoring and Grafana extensions are installed in Plesk Obsidian by default. You can find them located in the main left panel. The resources and services monitored by Advanced Monitoring are separated into five categories, with each one shown on its own tab.
If you upgrade to Plesk Obsidian from Plesk Onyx, Advanced Monitoring will automatically install and replace Server Health Monitor.
How to use the Advanced Monitoring extension
It’s incredibly easy to monitor your resources and server health using Advanced Monitoring. Most of its features are ready to go, but you can also customize it to suit your needs.
For example, you can select a time period for which Advanced Monitoring generates graphs. Or specify a custom period by selecting “Custom time range”. This can help you find out how your parameters change over time. As well as identify the periods when your resources usage is maximal or minimal.
You can also track your server health. Not only by looking at resources graphs, but by setting up and receiving Advanced Monitoring notifications. Advanced Monitoring can show notifications in Plesk’s interface when your resource usage exceeds its threshold and/or returns to normal value. The notifications only show for resources with notifications turned on and which have thresholds set in the Advanced Monitoring settings.
Certain resources already have their notifications turned on and their thresholds set by default. When a default threshold’s exceeded, it means a parameter is close to its critical value, which can be problematic. The automated-add on Grafana allows you to see detailed, visual reports on server health. And follow the real-time evolution for parameters that are of interest to you.
It offers numerous types of dashboards and can be used in two main ways:
  • With the data collected from default sources which were integrated for you by us.
  • (If you’re an experienced Grafana user) By harvesting data from any source you can integrate Grafana with.
We’re very excited about all Plesk Obsidian’s powerful new extensions. If you have any questions about Advanced Monitoring, be sure to leave us a comment below. Or get in touch with our friendly team of Pleskperts.
  • Yes, please, I agree to receiving my personal Plesk Newsletter! WebPros International GmbH and other WebPros group companies may store and process the data I provide for the purpose of delivering the newsletter according to the WebPros Privacy Policy. In order to tailor its offerings to me, Plesk may further use additional information like usage and behavior data (Profiling). I can unsubscribe from the newsletter at any time by sending an email to [email protected] or use the unsubscribe link in any of the newsletters.
  • This field is hidden when viewing the form
Related Posts
Knowledge Base
